landroversforever Posted March 25, 2023 Share Posted March 25, 2023 Make sure you post up another build thread for that one! 1 Quote Link to comment Share on other sites More sharing options...
NRS91 Posted March 27, 2023 Share Posted March 27, 2023 Ooo Disco2 based 609 axles? that would be interesting! Quote Link to comment Share on other sites More sharing options...
landy_andy Posted March 28, 2023 Author Share Posted March 28, 2023 19 hours ago, NRS91 said: Ooo Disco2 based 609 axles? that would be interesting! Afraid not, axles will be based on 99-04 Ford Super Duty inner C’s and knuckles, Inner half shafts are 1.5” 35 spline stock and the outer stubs get upgraded to 35 spline, both will be after market CrMo’s for extra strength. Unit bearings are SKF brand bored out to suit the 1.5” stub shafts with solid drive pucks. Rear axle will have weld on pockets for the unit bearings with double end splined half shafts and drive pucks again. 3rd’s are Ford 9” based in Yukon HD housings with ARB’s front & rear. Housings are the same fabricated centre sections as I built for the D100 with 3.5” x 3/8” wall tubes. Brakes will be Willwood Dynalite 6 piston calipers on custom brackets. Lots of wheel options available from cheap steels with a weld on beadlock kit right up to race spec double beadlocks… all depends how deep you pockets are ! 3 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted June 26, 2023 Author Share Posted June 26, 2023 Decided to make a full belly skid to prevent branches poking up through the seatbox when traversing clear cuts. 2 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted July 15, 2023 Author Share Posted July 15, 2023 All ready to be bolted up ! 1 Quote Link to comment Share on other sites More sharing options...
