Keeper96 Posted April 21, 2020 Share Posted April 21, 2020 Hi all, I’m about to start repairing my foot wells and have the panels from YRM and some seam sealer. my question is, does the seam sealer just get brushed over the seams once everything is welded in place or does it have to go in between the seams as well? thanks Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 21, 2020 Share Posted April 21, 2020 After it’s been welded. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 21, 2020 Share Posted April 21, 2020 Good luck with the job. Many people have done it and I'm in that group. There will be loads of pictures and stuff around if you need a help and you could take a look at my posts on the subject in my thread here from page 12: Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted April 21, 2020 Author Share Posted April 21, 2020 Cheers lads, I’ve been rebuilding my 90 and while I’m a fitter by trade we never touch bodywork or welding at work so all the chassis repairs and bulkhead work has been a real learning curve Quote Link to comment Share on other sites More sharing options...
andy _1 Posted April 22, 2020 Share Posted April 22, 2020 (edited) Right I guessing your new at welding not to worried. What I would tell you do do is drill holes in the panel you have ie small holes for spot welds, you get a 6mm or 8mm where your going to fix the new panel to the bulkhead , dont think you need to fit the full panel cut it down to fit , also to pull the panel in use tec screws before welding Edited April 22, 2020 by andy _1 Quote Link to comment Share on other sites More sharing options...
