Bigj66 Posted June 15, 2020 Share Posted June 15, 2020 Defender guys. Is PRC6021 the correct early speedo cable to fit to the LT230 and do the early speedometers have the same push on plastic cable connection in the rear as the series ones? Quote Link to comment Share on other sites More sharing options...
western Posted June 15, 2020 Share Posted June 15, 2020 PRC6021 is for a left hand drive vehicle, you need PRC6022 is for a right hand drive vehicle 1 Quote Link to comment Share on other sites More sharing options...
steve b Posted June 15, 2020 Share Posted June 15, 2020 90/110/Defender speedo fitting is different to the S3 cheers Steve b Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted June 15, 2020 Author Share Posted June 15, 2020 32 minutes ago, steve b said: 90/110/Defender speedo fitting is different to the S3 cheers Steve b At the speedo end? Quote Link to comment Share on other sites More sharing options...
steve b Posted June 15, 2020 Share Posted June 15, 2020 At both ends so a series 3 cable will not fit the LT230 TB speedo drive either . the speedo head on Defender style is a much bigger and longer coupling cheers Steve b Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted June 15, 2020 Author Share Posted June 15, 2020 2 hours ago, steve b said: At both ends so a series 3 cable will not fit the LT230 TB speedo drive either . the speedo head on Defender style is a much bigger and longer coupling cheers Steve b Oh bugger! Quote Link to comment Share on other sites More sharing options...
