steve b Posted April 19, 2021 Share Posted April 19, 2021 .....could be - simple to try and if it is that , a lot cheaper than having the FIP checked Steve Quote Link to comment Share on other sites More sharing options...
KenyaDefense Posted April 19, 2021 Author Share Posted April 19, 2021 BTW, I checked all fuel lines today, no pinches or anything abnormal. Is there any servicing that can be done on the FIP prior to removal that might indicate low fuel passage? Quote Link to comment Share on other sites More sharing options...
steve b Posted April 19, 2021 Share Posted April 19, 2021 Not that I can think of. Steve Quote Link to comment Share on other sites More sharing options...
monkie Posted April 19, 2021 Share Posted April 19, 2021 1 hour ago, KenyaDefense said: No smoke seems to indicate lack of fuel at combustion. I would have thought that poor injectors to cause noticeable drop off in power would cause knocking and smoking. I would be checking valve clearance when engine is cold and then follow up with a compression test. Quote Link to comment Share on other sites More sharing options...
KenyaDefense Posted April 19, 2021 Author Share Posted April 19, 2021 Will go after clearances tomorrow when the sun comes up... Will try the stop solenoid test first. Quote Link to comment Share on other sites More sharing options...
Will@LRW Posted April 19, 2021 Share Posted April 19, 2021 Check the black adjuster nut on the throttle cable to the rear of the FIP has all the slack taken out Quote Link to comment Share on other sites More sharing options...
KenyaDefense Posted April 19, 2021 Author Share Posted April 19, 2021 Got that already checked, thanks Quote Link to comment Share on other sites More sharing options...
monkie Posted April 19, 2021 Share Posted April 19, 2021 Here's a question for the Bosch VE experts that might help this situation... On the land rover 19J turbo diesel engine if you have a split boost diaphragm the CAV FIP is unable to give extra fuel to burn as the boost pressure increases causing a definite drop in power especially noticeable up hills. How does this mechanism work on the 300tdi, I'm assuming it must have parallels... Could a similar issue happen causing the problems the OP is observing? Quote Link to comment Share on other sites More sharing options...
KenyaDefense Posted April 19, 2021 Author Share Posted April 19, 2021 Boost diaphragm meaning the diaphragm inside the FIP? I have triple checked it, and even had my teenage son with better eyesight than me have a long gander, nothing. Quote Link to comment Share on other sites More sharing options...
monkie Posted April 19, 2021 Share Posted April 19, 2021 Yes, that is the thing I'm talking about. Quote Link to comment Share on other sites More sharing options...
KenyaDefense Posted April 19, 2021 Author Share Posted April 19, 2021 I question fuel delivery on and off boost. The boost diaphragm would only reasonably affect on-boost, right? But if the pin inside the FIP were slightly sticking, wouldn't that affect underfueling across the board? Quote Link to comment Share on other sites More sharing options...
KenyaDefense Posted April 21, 2021 Author Share Posted April 21, 2021 Sorry to inform, but all fuel is good. It is the clutch plate dying of all things! A friend came to give second opinion and knew immediately... Quote Link to comment Share on other sites More sharing options...
steve b Posted April 21, 2021 Share Posted April 21, 2021 Clutch slip ? Well on the plus side you now know the fuel system is all good.. Steve Quote Link to comment Share on other sites More sharing options...
