kevin50 Posted June 1, 2021 Share Posted June 1, 2021 Just about to start putting axles back together, on my 109.Didn't notice this extra hole when I took it apart, there was only 6 bolts. Anyone know why this extra hole is there ? it is same on both sides. Stub has 6 holes Quote Link to comment Share on other sites More sharing options...
Snagger Posted June 2, 2021 Share Posted June 2, 2021 If that is the front axle case, then a previous owner may have tried fitting later (coiler) swivels to have CV joints and disc brakes - their axles have an extra bolt at the bottom of the swivel challis. Otherwise, I don’t know - I’m not aware of any Series axles using seven bolts for the stub axles. Quote Link to comment Share on other sites More sharing options...
missingsid Posted June 2, 2021 Share Posted June 2, 2021 24 minutes ago, Snagger said: If that is the front axle case, then a previous owner may have tried fitting later (coiler) swivels to have CV joints and disc brakes - their axles have an extra bolt at the bottom of the swivel challis. Otherwise, I don’t know - I’m not aware of any Series axles using seven bolts for the stub axles. Except coiler bolts are clocked by 90 deg to Series bolts. That's how I could fit them to my S1 with 12 bolts and a spacer. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted June 2, 2021 Author Share Posted June 2, 2021 Its Rear Axle, stub has only the 6 holes Quote Link to comment Share on other sites More sharing options...
