Anderzander Posted June 7, 2021 Share Posted June 7, 2021 What’s going on here then .... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 7, 2021 Share Posted June 7, 2021 Looks like spark erosion... 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 7, 2021 Share Posted June 7, 2021 I did wonder if it was spark erosion.... but AFAIK (and what little of it I've done) it's done in a dielectric oil and that looks like water dripping out? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 7, 2021 Share Posted June 7, 2021 You're right Bowie, it is EDM: https://ppedm.com/e-drill/ 2 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 13, 2021 Share Posted June 13, 2021 Electro Discharge Machining (certainly with wire) just uses distilled water. The wire where I use to work had 2 huge cartridges in it with crystals of some description to distill the water before sending it back to the cutting head. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted June 13, 2021 Share Posted June 13, 2021 3 minutes ago, vulcan bomber said: Electro Discharge Machining (certainly with wire) just uses distilled water. The wire where I use to work had 2 huge cartridges in it with crystals of some description to distill the water before sending it back to the cutting head. Probably demineralised water then if there's crystals of some sort involved. Guess using water is a whole lot less messy than the oil! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 13, 2021 Share Posted June 13, 2021 3 hours ago, landroversforever said: Probably demineralised water then if there's crystals of some sort involved. Guess using water is a whole lot less messy than the oil! Demineralised might of been the word I was looking for. 1 Quote Link to comment Share on other sites More sharing options...
