Deem Posted October 10, 2021 Share Posted October 10, 2021 I have a new rear door for my ‘85 ninety. The old door had a rear wiper motor, however this was missing when i bought the car. Now I managed to buy a correct motor and need to fit it into the new door. I’m a bit puzzling with how to mount it properly. There is a seal, two washers and a nylon bushing. Can anyone tell me what is the right order is in combination with the door frame. See picture of the motor with parts. Thanks 🙏 Quote Link to comment Share on other sites More sharing options...
simonb Posted October 10, 2021 Share Posted October 10, 2021 Spacer goes between the door frame and skin, I would put one washer on the outside of the skin of the door so nut clamps on it, and the other between the frame and the motor. Rubber grommet goes through hole in skin. Top hat rubber washer goes over end of motor shaft, then wiper arm, then small nut. Quote Link to comment Share on other sites More sharing options...
western Posted October 10, 2021 Share Posted October 10, 2021 IIRC the rubber grommet goes on the inside --- you can just see it in my photos below so IIRC grommet/door frame/spacer/washer/, big nut on motor spindle thread/rubber boot/wiper arm, small nut. Quote Link to comment Share on other sites More sharing options...
Deem Posted October 11, 2021 Author Share Posted October 11, 2021 Thanks for the info 🙂 Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted October 12, 2021 Share Posted October 12, 2021 There should be two grommets - one on the inside, the other on the outside (I've just done mine!). Quote Link to comment Share on other sites More sharing options...
