Relays
heated rear screen relay & voltage sensitive switch [yellow case] lives in right front corner of dash, behind & to right of instrument pack & roughly inline with the 3 switches between door & steering column.
IF you have replaced the main/dash loom with the correct loom that has heated rear screen & rear wash/wipe, it will have the rear sockets included.
