Deep 52mm socket for 10 spline axle
2 hours ago, Mossberg said:
I measured up yesterday.  My existing socket is about 45mm deep.  I measured from the inner face of the nut to the outer end of the drive shaft needing 60mm.
Just get the long 52mm box spanner as linked to earlier, then you have the best of both tools.
1 hour ago, Anderzander said:
I do it Like this guy - and it works really well.
Yup, that's what I have and how I do it.
Out on the road or off it if I find a problem that needs fixing it can be done with grips as the tightness is not high.
I have seen Series motors where they used a punch and butchered the nuts, but using a flat faced punch you dont need that much effort!
