Rustyv8 Posted March 27, 2022 Share Posted March 27, 2022 (edited) Hi folks I have a 90 but have fitted Disco 1 axles front and rear. I want to fit dust shields to the rear as there are a lot of unfinished roads and forest paths here in Finland. Does anyone have a photo of theirs maybe they can share, although I know many of removed them. But I wont be doing heavy mud stuff Do they just bolt to the axle directly or do I need these brackets FTC3299. Do I have to strip the hub, disks etc to fit like on the front or do these fit on the rear side near, i.e the diff side. p.s and are there any specific bolts to fit them, is the axle tapped...tks! Any help appreciated. Alan Edited March 27, 2022 by Rustyv8 Quote Link to comment Share on other sites More sharing options...
western Posted March 27, 2022 Share Posted March 27, 2022 Diagram in here may help http://lrcat.com/#32/4/45425 Yes hub & caliper need to be removed to fit the shields Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 27, 2022 Share Posted March 27, 2022 I don't know if this helps any. https://www.landrovermonthly.co.uk/articles/how-to/rear-disc-brakes-defender-discovery/ Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 27, 2022 Share Posted March 27, 2022 This may help too. It's the image of the axle I bought for the casing as I was taking it appart. Quote Link to comment Share on other sites More sharing options...
Rustyv8 Posted March 27, 2022 Author Share Posted March 27, 2022 (edited) Thanks guys / my issue is that I couldntsee WHERE they fit on the rear. I was actually replacing all the bearings and disks yesterday and was planning to fit the shields then, but I didn’t realize until too late that I needed brackets!! @Mossberg...super.. so if im looking right, the brackets are also using the caliper mounting points, is that right? And presumably just the caliper bolts also then.... and if so can I just slip these on the back by removing the caliper bolts without removing the hub and disks again? Edited March 27, 2022 by Rustyv8 Quote Link to comment Share on other sites More sharing options...
Mossberg Posted March 27, 2022 Share Posted March 27, 2022 27 minutes ago, Rustyv8 said: Thanks guys / my issue is that I couldntsee WHERE they fit on the rear. I was actually replacing all the bearings and disks yesterday and was planning to fit the shields then, but I didn’t realize until too late that I needed brackets!! @Mossberg...super.. so if im looking right, the brackets are also using the caliper mounting points, is that right? And presumably just the caliper bolts also then.... and if so can I just slip these on the back by removing the caliper bolts without removing the hub and disks again? I am just starting on this job myself so please be aware that others will be far better to give you good advice than me. However I think you are correct. I think the bracket will be where you would have a washer with the caliper against the axle casing. Quote Link to comment Share on other sites More sharing options...
Rustyv8 Posted March 27, 2022 Author Share Posted March 27, 2022 Coolio... thanks.... brackets are ordered now so hopefully i can figure it out when i get them. Quote Link to comment Share on other sites More sharing options...
