Ryan1997_300TDI Posted February 1, 2023 Share Posted February 1, 2023 Hey all, I am having a heck of a time figuring out whether the bearing my mechanic pulled from my Discovery 1 1997 300tdi is standard or oversized and we need to replace them. The problem is that the markers on the bearings don't come up in a google search or in the parts manual. I have attached a picture. Does anyone know anything about these bearing markers? If they are standard, oversized or which manufacturer they belong to? G • D ERR6993 MB. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2023 Share Posted February 1, 2023 Not on Turner Engineering website 300tdii engine parts either with that part number & not on LRCAT parts listing. Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 2, 2023 Share Posted February 2, 2023 If undersized, they should be stamped with the altered spec, much like oversize pistons. I would be confident those are standard shells. Quote Link to comment Share on other sites More sharing options...
hurbie Posted February 2, 2023 Share Posted February 2, 2023 bit of a strange question i would think , your mechanic needs to measure the crankshaft journals and figure the right size from a chart in the manual ..... that beats putting the wrong bearings in found by some obscure number 🙂 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 3, 2023 Share Posted February 3, 2023 11 hours ago, hurbie said: bit of a strange question i would think , your mechanic needs to measure the crankshaft journals and figure the right size from a chart in the manual ..... that beats putting the wrong bearings in found by some obscure number 🙂 Quite. Unless doing a bit of a lash-up refresh of an engine without taking it apart, there would be no reason to trust that a crank hadn’t worn or marked a little and didn’t need a grind or polish and subsequent underside bushes, and there would be little excuse to trust that the previous bushes were correct anyway. But I can see why it’s tempting to throw new bearings in on a tidy but used engine without removing the crank shaft. Quote Link to comment Share on other sites More sharing options...
hurbie Posted February 3, 2023 Share Posted February 3, 2023 5 hours ago, Snagger said: But I can see why it’s tempting to throw new bearings in on a tidy but used engine without removing the crank shaft. but that leaves the question how do you change the last one (close to the gearbox) Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 3, 2023 Share Posted February 3, 2023 58 minutes ago, hurbie said: but that leaves the question how do you change the last one (close to the gearbox) It’d be a bodge, but on some engines it may be possible to replace at least the lower shell - the upper should have little wear as the compression and combustion strokes push the crank against the lower shells. I’d need to see an engine up close to see if that could be done, but I suspect it could. Not sure if it’d disturb the block to flywheel housing gasket or, on the 300, the rear crank seal too much. I’d be wary of that on the 300. 1 Quote Link to comment Share on other sites More sharing options...
