timbr00 Posted March 9, 2023 Share Posted March 9, 2023 I have recently come into possession of a 1986 110, previous owner had fitted off road driving lights but not wired them in. I have now done so as per the attached diagram. the problem I have is they don't work! I have disconnected the connector of blue/grey cable just behind the driver side headlight and spliced cable from headlight/main beam switch/new switch supply cable. these are my findings: all 3 cables joined - all existing lights work correctly except spots which are inoperative. with the main beam switch cable disconnected - driver headlight very dim- passenger headlight full beam & spots operate correctly. can someone please help as i'm getting very frustrated at what must be a quite simple fix and just can't get my head around it!!! Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2023 Share Posted March 9, 2023 Try this diagram & reconnect your relay to match. Quote Link to comment Share on other sites More sharing options...
timbr00 Posted March 9, 2023 Author Share Posted March 9, 2023 isn't that what I have done? with the exception of 85-86 on the relay which are transposable. both diagrams look identical to me? 15 minutes ago, western said: See above, in the linked post, don't know why the diagram wouldn't show correctly. Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2023 Share Posted March 9, 2023 Well yes, Blue with Grey trace is LH main beam, RH main is Blue with Orange trace. These are the vehicles left & right regardless of where you are looking from. Are the main beam fuses in fuse box good? Quote Link to comment Share on other sites More sharing options...
simonpelly Posted March 10, 2023 Share Posted March 10, 2023 (edited) Diagram looks good to me. Suggest it is time for Mr. Multimeter 🙂 Edited March 10, 2023 by simonpelly Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 10, 2023 Share Posted March 10, 2023 31 minutes ago, simonpelly said: Diagram looks good to me. Suggest it is time for Mr. Multimeter 🙂 Same here, diagram looks fine apart from the implied use of a scotchlok I'd start poking round to see where the dodgy connection is. Dodgy earth would not be a surprise. Quote Link to comment Share on other sites More sharing options...
Def Harry Posted March 10, 2023 Share Posted March 10, 2023 If you remove the new switch and directly connect the feed wire spurred off the high beam feed to pin 85 on the relay/that wire - what happens? Quote Link to comment Share on other sites More sharing options...
timbr00 Posted March 10, 2023 Author Share Posted March 10, 2023 just thought id post the solution. for some reason it doesn't like it when tapped into at the headlight bulb connector. connecting it to the spotlight warning light fixed the issue. Quote Link to comment Share on other sites More sharing options...
