Anderzander Posted April 20, 2023 Share Posted April 20, 2023 On the Td5 you can disable the interior alarm sensor by locking it with a key / but my dog spends so much time in there I’d rather use the fob. It has one of those ultrasonic sensors : With 3 wires - two to the ECU and one to earth. If I want to pop a switch in there to be able to disable/enable it, anyone have any idea where I should put it? Quote Link to comment Share on other sites More sharing options...
smallfry Posted April 20, 2023 Share Posted April 20, 2023 Couldn't even begin to answer that, but wouldn't the alarm or BCM know its AWOL and throw up a fault ? Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 20, 2023 Author Share Posted April 20, 2023 Apparently not - as if you unplug them everything’s fine. It’s just for a convenience - but for me it will be one of those small things that makes a disproportionate improvement. 1 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted April 21, 2023 Share Posted April 21, 2023 In that case you could open circuit the two cables WB and BN , using a standard double pole switch, leaving the B cable connected. 1 Quote Link to comment Share on other sites More sharing options...
