Green200tdi Posted June 8, 2023 Share Posted June 8, 2023 Hello spraying chassis the weekend fingers crossed, new to painting with a gun so could use some advice, if I ever need paint advice I’d ask dad but sadly he passed away,😪 so my question is what ratio of thinners to chassis paint do I need? thank you. Quote Link to comment Share on other sites More sharing options...
Paul C Posted June 9, 2023 Share Posted June 9, 2023 What does the paint recommend, usually it will tell you on the label, mine said if required, but I found it sprayed fine without thinning. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted June 9, 2023 Share Posted June 9, 2023 Enough to get it to spray nicely to thick it'll spit and have a patchy pattern, if your only spraying your chassis your not worried about a bit of orange peel, less thinners equals less flow out but more paint. More thinners allows it to flow giving a better finish but less thickness. Mike Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 9, 2023 Share Posted June 9, 2023 I add a splash at a time until it no longer drags when you stir it in the cup. Don't forget to wash the setup out at the end with some neat thinners blown through the gun. Quote Link to comment Share on other sites More sharing options...
steve b Posted June 9, 2023 Share Posted June 9, 2023 When you spray into internal corners like outriggers and rear x-member turn the spray cone setting to minimum to narrow it and force the paint into corners, also useful for little brackets - rear x-member tabs etc. Do the edges of the rails with the small cone pattern too first then set to fan pattern for the flat area's and lastly it's the chassis some more is good and the odd drip or run is fine Wear a mask and watch out for where the over spray goes. Set the air reg. to 40psi to start with and go up or down to suit your mix and gun. Steve 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 9, 2023 Author Share Posted June 9, 2023 Thank you all, let’s hope the weather is with me the weekend.😊 1 Quote Link to comment Share on other sites More sharing options...
Paul C Posted June 10, 2023 Share Posted June 10, 2023 I repainted mine after the sandblaster had painted it for me but had missed lots of little corners and everytime I looked I saw little orange spots, so got two engine stands and a temporary carport and sprayed it again with about 4 coats of chassis black, much easier when rotating it to get everywhere you need to. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 10, 2023 Author Share Posted June 10, 2023 3 hours ago, Paul C said: I repainted mine after the sandblaster had painted it for me but had missed lots of little corners and everytime I looked I saw little orange spots, so got two engine stands and a temporary carport and sprayed it again with about 4 coats of chassis black, much easier when rotating it to get everywhere you need to. I only have one engine stand unfortunately we shall try our best today tho 😊 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 11, 2023 Author Share Posted June 11, 2023 Well yesterday was a great day managed to get chassis on to the drive clean it up and spray it with my new gravity fed spray gun, cheep as chips at £20,49 yes my 50 litre compressor was constantly running so sprayed a bit and let the compressor rest, all is well chassis painted so thank you all for your help. Mark. 2 Quote Link to comment Share on other sites More sharing options...
