need4speed Posted July 6, 2023 Share Posted July 6, 2023 After talking to Nige recently he advised we needed upgraded spark plugs, a lead to allow ecu to talk to laptop, and latest disc with 4.6 map on it. The engine running so rich there was more petrol in sump than oil Nige was supposed to send me a request to my PayPal for the above stuff but I haven’t heard from him since What are the best plugs to use? Also what is the best lead to use? Is there one available to connect to more modern laptops or is it still the old connector style? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 6, 2023 Share Posted July 6, 2023 BPR6ES are perfect really, no benefit to be had from anything more modern. This adapter works perfectly to convert USB to serial, windows or mac: https://amzn.eu/d/hkSwKvd If your engine is running rich, don't assume it is MS, if it is getting bum signals, e.g. Coolant temp, or even a knocked off Map hose it will run stinking rich. So what's changed? The MS map hasn't, it won't do that by itself.... If it has had any tuning in the past replacing the map with one from a 4.6 is just going to put it back to square one. Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 6, 2023 Author Share Posted July 6, 2023 Nah it’s not had any tuning whatsoever. Think that’s the problem. It’s not been hooked up to tuner at all as yet. The cts is brand new. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 6, 2023 Share Posted July 6, 2023 Get the laptop hooked and go from there, otherwise you're shooting blind. Tbh I got a Bluetooth adapter and do a lot of my tuning from my phone with MSDroid. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 6, 2023 Share Posted July 6, 2023 Nige has been recoverying from an operation so may just need a bit more patience than normal, I'm certain he'll help you out when he's able. Good luck with this though, you've been at it for almost as long as I had and I'm sure it'll be worth the wait. Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 6, 2023 Author Share Posted July 6, 2023 Thanks guys. Is the disc available from Niges site? Yeh mate we’ve been at it too long. Unfortunately life has thrown a lot of curve balls and I never get to spend long at it. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 6, 2023 Share Posted July 6, 2023 You don't need a disc, just download tunerstudio and fire it up. Roll back the required fuel setting until it stops stinking, that's assuming everything else is looking OK. Quote Link to comment Share on other sites More sharing options...
need4speed Posted July 6, 2023 Author Share Posted July 6, 2023 **** I wish you weren’t so far away. You could probably sort my probs in a day Quote Link to comment Share on other sites More sharing options...
