Lockylockwood Posted January 3 Author Share Posted January 3 I should also add that with the heater and the lights on the Voltage is 13.1 Quote Link to comment Share on other sites More sharing options...
Shep The Disco Posted January 3 Share Posted January 3 Crank shaft bearings are failing most likely. See how long it takes for the battery to get the hell knocked out of it trying to start the heavier engine rotation... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 3 Share Posted January 3 If you have 13v with the engine running and things switched on then the alternator is charging the battery. Whatever is wrong with the engine would be a separate thing, the only way the alternator could drag a 200TDi down is if the it seized up but even then it would make a hell of a noise and shred the V-belt. Quote Link to comment Share on other sites More sharing options...
Escape Posted January 4 Share Posted January 4 Put a socket and a breaker bar on the crank bolt and see if the engine turns freely or not. Accounting for compression of course. If something is indeed dragging it down enough to keep it from revving freely, that will have a serious impact on the starter motor as well, with increased current draw so anything amiss with the starter circuit will be highlighted. 1 Quote Link to comment Share on other sites More sharing options...
