evanmc Posted January 28 Share Posted January 28 1985 110 2.5NA I need a bit of help here replacing a component of the ignition switch for my 110. Specifically, how to remove the old component and attach the new one. Can this be done in-place, or do I need to remove the entire assembly and perform this on the bench? (Replacing NRC3908) Thanks -Evan- Quote Link to comment Share on other sites More sharing options...
Paul C Posted January 28 Share Posted January 28 There should be screws to hold it into the housing. If you can do those in place then OK, but probably easier to remove the whole lock first. Quote Link to comment Share on other sites More sharing options...
evanmc Posted January 28 Author Share Posted January 28 46 minutes ago, Paul C said: There should be screws to hold it into the housing. If you can do those in place then OK, but probably easier to remove the whole lock first. I'll check again, then. I felt around the barrel and did not feel them. Hoping to avoid messing with the shear bolts that holds it in place, but may have no choice. Quote Link to comment Share on other sites More sharing options...
western Posted January 28 Share Posted January 28 2 small pan head screws secure the electrical part to the body of the switch assembly, The screws maybe raised or countersunk in the body casting Quote Link to comment Share on other sites More sharing options...
evanmc Posted January 29 Author Share Posted January 29 Should have disassembled before I ordered off the parts fiche. The switch does not have shear bolts, and is not attached directly to the steering column. Also, there are no screws to hold in the electrical bits. It's ex-MOD, if that makes a difference. Quote Link to comment Share on other sites More sharing options...
Paul C Posted January 29 Share Posted January 29 That is a one piece switch, no steering lock. PRC2734 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted February 1 Share Posted February 1 (edited) These are the squezing screws, securing the switch Once I had to repair the switch. I turned the contact for the starter 180°. As you can see, the contact obviously was eaten from a spark each time I started Edited February 1 by Sigi_H Quote Link to comment Share on other sites More sharing options...
