Green200tdi Posted February 9 Share Posted February 9 Hello all, can you buy axle breather pipe by the metre? plastic not rubber if so have you a link, thanks Quote Link to comment Share on other sites More sharing options...
pat_pending Posted February 9 Share Posted February 9 6mm pneumatic pipe. At your local hydraulics store or ebay, same as the fittings. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 9 Author Share Posted February 9 23 minutes ago, pat_pending said: 6mm pneumatic pipe. At your local hydraulics store or ebay, same as the fittings. Lovely thanks Quote Link to comment Share on other sites More sharing options...
fmmv Posted February 9 Share Posted February 9 Slight hijack but on rhis subject, the later plastic fuel tanks seem to have a breather with a rollover valve, either dirctly on the tank or teed into the breather that is part of the filler. Do these not need to be extended like the rear axle breather to a height where water is unlikelt to be? Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted February 10 Share Posted February 10 This is a pneumativ pipe, but they break from vibrations. A lot better is to use PA pipes instead of PU. You will get it at the pneumatic dealer as well. Normaly it is used for center greasing of trucks. I used PA pipes very succesful for leak pipes at the injectors and fuel pipes. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted February 10 Author Share Posted February 10 5 hours ago, Sigi_H said: This is a pneumativ pipe, but they break from vibrations. A lot better is to use PA pipes instead of PU. You will get it at the pneumatic dealer as well. Normaly it is used for center greasing of trucks. I used PA pipes very succesful for leak pipes at the injectors and fuel pipes. I’ve used window washer pipe for the injectors been on there 5 years now 😂 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 12 Share Posted February 12 On 2/9/2024 at 8:44 PM, fmmv said: Slight hijack but on rhis subject, the later plastic fuel tanks seem to have a breather with a rollover valve, either dirctly on the tank or teed into the breather that is part of the filler. Do these not need to be extended like the rear axle breather to a height where water is unlikelt to be? Yes it is wise to rise the tank breather as well. This can be troublesome on hardtops and csw's as you don't want either the axle or tank breathers inside. Mike 1 Quote Link to comment Share on other sites More sharing options...
