mad_pete Posted May 4 Share Posted May 4 My sump plug seems to be quite set on staying put so I was wondering about getting an oil extractor and avoid the issue. People had success with those and the rover V8 dipstick tube ? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted May 5 Share Posted May 5 I think you'll struggle to get everything out of the bottom. Even the best ones with engines designed for top down servicing don't get everything out of the sump. What about sucking as much as you can and then removing the sump? 1 Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted May 5 Share Posted May 5 7 hours ago, Ed Poore said: What about sucking as much as you can and then removing the sump? This, and while the sump is off, fix the plug. 1 Quote Link to comment Share on other sites More sharing options...
