Green200tdi Posted June 23 Share Posted June 23 (edited) Hi all, so for some years now I’ve had the defender td5 electronic speedo in my 1986 110 worked a treat then I upgraded the loom to a td5 defender loom still working well, so in 2020 I put the vehicle in to storage as it failed the mot on rust, so last year I set about rebuilding it it’s come along well so far I done all the wiring including speedo but today had the car up in the air wheels turning no speedo sure I wired it up correctly any way of testing the system it’s got NO ecu can I put a live to the transducer plug for the signal see if it moved needle coukd be my transducer is knackard Edited June 23 by Green200tdi Quote Link to comment Share on other sites More sharing options...
western Posted June 23 Share Posted June 23 Probably a dead transducer or the plug isn't fully connected, the should be 3 wires, Earth, Signal to Speedo, 12v feed Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 23 Author Share Posted June 23 21 minutes ago, western said: Probably a dead transducer or the plug isn't fully connected, the should be 3 wires, Earth, Signal to Speedo, 12v feed I’ll try the plug I’m pretty sure the transducer is knackered was lying about in my tool box 😂 if I was to put a live to signal wire on plug would it not move speedo let me know it’s ok? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23 Share Posted June 23 No, it's a hall sender most likely. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted June 23 Author Share Posted June 23 1 hour ago, western said: Probably a dead transducer or the plug isn't fully connected, the should be 3 wires, Earth, Signal to Speedo, 12v feed I’ll try the plug I’m pretty sure the transducer is knackered was lying about in my tool box 😂 if I was to put a live to signal wire on plug would it not move speedo let me know it’s ok? ok I’ll play with the plug if no joy I’ll wait till I get new transducer.👍 thanks Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted June 24 Share Posted June 24 Isn't the transducer in the LT230? That does not necessarily spin, when only 1 wheel is turned = no speedo Quote Link to comment Share on other sites More sharing options...
western Posted June 24 Share Posted June 24 Yes it's on the rear housing of transfer box, Quote Link to comment Share on other sites More sharing options...
