TD5 speedo in a 1986 110
Hi all,
so for some years now I’ve had the defender td5 electronic speedo in my 1986 110 worked a treat then I upgraded the loom to a td5 defender loom still working well,
so in 2020 I put the vehicle in to storage as it failed the mot on rust,
so last year I set about rebuilding it it’s come along well so far I done all the wiring including speedo but today had the car up in the air wheels turning no speedo sure I wired it up correctly
any way of testing the system it’s got NO ecu can I put a live to the transducer plug for the signal see if it moved needle
coukd be my transducer is knackard
Edited by Green200tdi
21 minutes ago, western said:
Probably a dead transducer or the plug isn't fully connected, the should be 3 wires, Earth, Signal to Speedo, 12v feed
I’ll try the plug
I’m pretty sure the transducer is knackered was lying about in my tool box 😂
if I was to put a live to signal wire on plug would it not move speedo let me know it’s ok?
I’ll try the plug
ok I’ll play with the plug if no joy I’ll wait till I get new transducer.👍
 thanks
