Yostumpy Posted February 16, 2007 Share Posted February 16, 2007 Hi. my water pump bearing squeaks when cold or damp mornings, temperally cured by a careful squirt of wd 40. Is this the start of a rapid decline ending in replacement, or just land rover engineering. no leaks though!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Warthog Posted February 16, 2007 Share Posted February 16, 2007 It will get really anoying after awhile! A new water pump is cheap as. Just hope the bolts come out easily and getting the P gasket to seal proper can be a bugger! There's a thread on here somehere? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 17, 2007 Share Posted February 17, 2007 If there is a "telltale" hole under the shaft of the pump see if you can get some WD40 or something a bit thicker up there, could help. The pump on the 109 made a horrible noise for months before giving out Quote Link to comment Share on other sites More sharing options...
freeagent Posted February 19, 2007 Share Posted February 19, 2007 if you buy a new pump, spend the money and buy genuine, and fit a new, genuine parts gasket aswell... the Britpart waterpump i bought a couple of years ago lasted 11 days, and the gasket was little more than newspaper.. genuine parts are only about £50... you might need to change the housing gasket aswell... make sure you use a smear of sealant... Quote Link to comment Share on other sites More sharing options...
JST Posted February 20, 2007 Share Posted February 20, 2007 i would change it now why you can, eg on the driveway rather than spend a weekend waiting for recovery man on the side of a motorway etc. Quote Link to comment Share on other sites More sharing options...
