ltwt1981 Posted September 28, 2005 Share Posted September 28, 2005 My set up is on a four cylinder but uses a cap with (for arguments sake) a tin can screwed on over it. I have a full set if you want a look. Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted September 28, 2005 Share Posted September 28, 2005 the dizzy used for v8 engines is the 35DML8 which is a standard dizzy used for 3.9's just a different cap and the coil has a plug on cap thing to the satndard coil I saw a set of these at Bling a couple of years ago, guy wanted over 200 unwarranted, did look seriously military though. I was tempted to put the dizzy cap on my head to do a Dvros of the Daleks impression but the wife's look said it all Don't make yourself look even sillier than you do already I am tempted every time I look at the DUI units, for coolness alone it's almost worth it B) The chip fat burners are not immune to water either. Hey Niall, run through there fast to push a bit more water out for us V8's - Duh OK, cheers Kim I wasn't exactly prepared I am ashamed to say Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 28, 2005 Share Posted September 28, 2005 diesels not waterproof? I'll have to tell Jerzy that he always seems to be driving through one lake or another thanks to Zebra Offroad Club Poland for a topscore playday To quote the bloke from Davies Unified Ignition - its water resistant sir, not waterproof Quote Link to comment Share on other sites More sharing options...
02GF74 Posted September 29, 2005 Share Posted September 29, 2005 Clever bloke that Jerzy - he even extended his gear lever so it is visible above water No doubt he will be fitting a periscope next!!!! Re: the military V8 caps - are they meant to be waterproof or is the screening for supressiong ignition RF? Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 29, 2005 Share Posted September 29, 2005 ahh thats only his fiddle brake, he's still got the gearlever, transferbox lever, pto lever, front/rear winch select lever, handbrake lever to fish around for He says the bubble in the roof his bus has enough air for a good few minutes so a mask, flippers and snorkel would just be showing off but a periscope.... hmm I'll see what he says B) screened caps should offer good protection from water with a little judicious silcone enhancement - or you can fit them up with HT leads and then pot them in potting compound, if you are looking for coil on cap then have a nose at the newer Suzuki GSXRs (they all had them), big dollop of silicone and wire them into a bank will see the job done. We used the same setup on a floating motorbike to ride accross a lake for a competition and that was happy as larry underwater Quote Link to comment Share on other sites More sharing options...
ltwt1981 Posted September 29, 2005 Share Posted September 29, 2005 I think they are screened, water can still get in. The military did waterproofing kits for land rovers as well. Quite a lot of work to do the job properly because they do everything including the dash instruments etc. The ignition screening could I think be made watertight with a bit of effort though. It should already help Ie splashproof/water resistant. The plugs are probably the easy bit as it all screws together and they are supposed to be good quality, although expensive from land rover. I have two sets but at present don't use them although putting them back in is a future project. I have Aldon ignition in the lightweight and it really does work a treat. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted September 29, 2005 Share Posted September 29, 2005 We used the same setup on a floating motorbike to ride accross a lake for a competition and that was happy as larry underwater I take it it wasn't quite so successful in other respects then Quote Link to comment Share on other sites More sharing options...
dollythelw Posted September 29, 2005 Share Posted September 29, 2005 it had outriggers and a 40hp outboard but they way we built it meant that the bikes engine was underwater when it was in "boat" mode - it meant you could still ride it round the shore and then ride straight into the lake and re-stage a baywatch style rescue (complete with slow motion running) mmmm slow motion..................... I better go now Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted September 29, 2005 Share Posted September 29, 2005 It was a bit deeper than it looks in that piccy, there is a Fiesta behind with the roof just showing, wife had her dainty feet on the dash. Climbed out and called for a tow, everybody ran away, stout fellows I thought until they appeared back without a rope or tow vehicle, but every last one of them had a camera That Jerzy guy takes the biscuit though, the Poles are real fun nutters, wifes father was Polish. handbrake lever to fish around for Tell me that was unintentional please Back OT Even after the dunking and we had bumped the water out of the cylinders the alternator and starter still worked OK, what surprised me more was no water got into the sump even with water obviously in the cylinders. I will not mention what make of engine it is here for obvious reasons. Quote Link to comment Share on other sites More sharing options...
