ibexman Posted October 2, 2005 Share Posted October 2, 2005 Is there an adaptor to convert a sankey trailer plug to civvy type caravan socket or do i have to chop itoff and replace with a civvy plug???? Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2005 Share Posted October 2, 2005 get another nato socket & 7 pin 12n plug and build your own adaptor lead Quote Link to comment Share on other sites More sharing options...
ibexman Posted October 2, 2005 Author Share Posted October 2, 2005 get another nato socket & 7 pin 12n plug and build your own adaptor lead cheers for that ralph Quote Link to comment Share on other sites More sharing options...
02GF74 Posted October 3, 2005 Share Posted October 3, 2005 Is there an adaptor to convert a sankey trailer plug to civvy type caravan socket or do i have to chop itoff and replace with a civvy plug???? no. you have 4 choices: 1. do what ralph suggests (mil socket is expensive and quite hard to source) also mil socket is panel mounted so not ideal for this purpose. 2. fit caravan socket instead of the nato traler socket. 3. fit both type sockets on crossmember 4. fit mil socket and make converter lead to civ. socket - there should be more mil. plugs around due to people opting for 2. and I think you can buy civ. sockets that are not panel mounted. If you go with 2. make sure you have the pin wiring info. and label the cables first - AFAIK the wiring to the plug in the sankey is all one colour - yellow! Quote Link to comment Share on other sites More sharing options...
Divster Posted October 3, 2005 Share Posted October 3, 2005 Mil sockets and plugs now available from RS Components: 510-7358ZR Cable plug £28.61 510-7516ZR Cable socket £30.04 510-7673ZR Chassis Plug £26.04 510-8137ZR Chassis Socket £26.75 510-7673ZR Jam Nut Plug £26.04 510-7825ZR Jam Nut Socket £27.85 510-8288ZR Plug Dust Cap £16.56 see rswww.com for further details Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 3, 2005 Share Posted October 3, 2005 NATO connections in the plug are: A,C,H Red/Brown Convoy B,J Green/Purple Stop D,L Black Earth E Red/Orange Tail lights F Red/Yellow Fog Lights K Purple Auxiliary M Green/Red LH Flash N Green/White RH Flash Quote Link to comment Share on other sites More sharing options...
