TIC Half Shafts
ltwt1981
Yes so it seems but they come with the outer flange etc as well.
Metal looks OK, the proof of the pudding will be in if they last, at £110 for two a couple of years would be OK, I've broken 4 in the last 12 months.
Nige, yes they asked me to trial at Nellys last year when I scrutineered but had to decline on non compliance grounds. Would have passed scrutineering no trouble though!
I spoke to Ed last night on another subject, will be in touch.
Tonk I like to be gentle with mine, treat it like a woman and all that.
Here are some pictures, I have some more but these should help.
Sorry they are big but I thought it would be better for these Nige T
it would be worse if they weren't in focus :)
Would I be righ to say that they are larger in diameter than standard - looking at the end with the threaded bit (wheel end) and the step in the splines to make the diameter smaller?
I'll see what I can do.
Very likely your camera is focussed on the background.
Most cameras, inluding digital, have a focus lock achieved by partially pressing the shutter release (usually a visual indicator e.g. green LED is lit). You then back the cameera off a little bit to allow for the thickness of the half shaft and fully depress the shutter release. It may take a few attempts to get it sussed.
Right here goes.
Splines outer ends 28.3mm
Splines inner ends 28.3mm
Diameter of long shaft 27.25mm
Diameter of short shaft 27.15mm
(Different batch maybe?)
Long shaft excluding threads 886mm long
Short shaft excluding threads 629mm long
Sorry for photo quality but these were taken a 7am before going to work, if needed I could take some more before fitting.
I will measure the old shafts when they come out as a comparison.
