rtbarton Posted April 4, 2007 Share Posted April 4, 2007 We currently run our database under DOS and have just upgraded to XP. The database runs fine but the DOS program won't recognise the USB port. Is there any way I can redirect LPT2 (which doesn't exist physically) to the USB printer. The database will only recognise LPT1...4 and COM1..4 Or will the answer be to fit another parallel port? Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted April 4, 2007 Share Posted April 4, 2007 Fit another parallel port as some older printers do not like working thro a usb lead. But you can get a parallel to usb converter. Paul Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 4, 2007 Author Share Posted April 4, 2007 Fit another parallel port as some older printers do not like working thro a usb lead. But you can get a parallel to usb converter.Paul Thanks Paul. The problem is with the DOS program not being able to recognise the USB port. I was wondering if it was possible to redirect the logical port LPT2: to the physical USB port as the new printers are USB I've told the spares sec. to get another LPT port, but I was wondering if there was a more elegant method. Quote Link to comment Share on other sites More sharing options...
RRX Posted April 4, 2007 Share Posted April 4, 2007 This should work, Share the printer on the pc then go start, run and type net use lpt1 \\{nameofyourpc}\{nameofprintershare} then install a copy of the usb printer on lpt1 i think thats how i normally get round the issue but not had to do it for a while Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 4, 2007 Author Share Posted April 4, 2007 This should work,Share the printer on the pc then go start, run and type net use lpt1 \\{nameofyourpc}\{nameofprintershare} then install a copy of the usb printer on lpt1 i think thats how i normally get round the issue but not had to do it for a while OK - but LPT1: is used for one printer (labels) and the other printer (USB) for invoices, we need to specify the invoice prinetr as LPT2: Quote Link to comment Share on other sites More sharing options...
RRX Posted April 4, 2007 Share Posted April 4, 2007 type lpt2 then Quote Link to comment Share on other sites More sharing options...
steve_a Posted April 4, 2007 Share Posted April 4, 2007 get rid of the dos program? What is the program, I might be able to help in converting it to something a bit less antique. It's asking for issues really still using a DOS program at this stage, you might find the bugger stops running on Vista or even a processor change, a lot of dos programs were written in Assembly and life has moved on a lot since then. you might find the net use trick (neat by the way) doesn't work as it could be doing a lot of low level stuff to access the printer? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted April 5, 2007 Author Share Posted April 5, 2007 get rid of the dos program? What is the program, I might be able to help in converting it to something a bit less antique. It's asking for issues really still using a DOS program at this stage, you might find the bugger stops running on Vista or even a processor change, a lot of dos programs were written in Assembly and life has moved on a lot since then.you might find the net use trick (neat by the way) doesn't work as it could be doing a lot of low level stuff to access the printer? Hi Steve, I agree with waht you say, but I was presented with a fate accompli. The DOS program is DataEase which is excellent for our application. We have "upgraded" to the Windows version which is carp, to use on the XP machine. The spares sec wants to use the DOS version on the XP machine until we get the Windows version running (don't know why) but we're having issues with the printer. We will have further issues when we use the Windows version as it looks like we can't allocate specific printers to individaul reports. I wondered about using another database and have looked at several, one wouldn't even right justify numbers!! There's a lot of carp out there! If I had my way we'd have a dedicated machine for the database running MSDOS and nothing else. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted July 7, 2007 Author Share Posted July 7, 2007 We installed an LPT2 port, this was a fancy thing with a driver CD and DOS still didn't recognose it, although XP did. I have found this little program though DOS Print Utlilty. Basically you have to configure your DOS pogram to print to a file, as soon as this utlilty sees the file it prints it to a Windows printer. You can specify upto 4 channels. Next question - can I supress the form feed when XP finishes printing the print queue? Quote Link to comment Share on other sites More sharing options...
