JST Posted April 7, 2007 Share Posted April 7, 2007 i can't remember! they are MTs and cant remember if you need to trim the arches to stop them catching on articulation? Quote Link to comment Share on other sites More sharing options...
white90 Posted April 7, 2007 Share Posted April 7, 2007 they'll rub slightly on articulation unless a suspension lift is added nothing to worry over though. M005 Had them on his standard height 90 Quote Link to comment Share on other sites More sharing options...
gelf Posted April 7, 2007 Share Posted April 7, 2007 never trimmed them on mine......... Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 7, 2007 Share Posted April 7, 2007 James, yep, the Mt's will fit on the TD5, with your new standard ?? springs, All ready for 4 weeks time !! Quote Link to comment Share on other sites More sharing options...
JST Posted April 8, 2007 Author Share Posted April 8, 2007 Tim - will just be changing the MTs over, springs wont be done for a while, was just after thoughts, its only the front that is low anyway! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 8, 2007 Share Posted April 8, 2007 I had 255/85 with standard (12yo) springs and they rubbed slightly on articulation. Fine for normal use, arches untrimmed. Quote Link to comment Share on other sites More sharing options...
DSN Posted April 9, 2007 Share Posted April 9, 2007 Mine are on Wolf rims and no issues on front (other than a slight reduction in steering lock) but on the rear, they caught the back edge of the eyebrow slightly. A trim from the rear most corner direct to the leading edge (get rid of the slight 'corner' they have) seemed to solve that. With standard bump stops they rub slightly on the tub on compression but not worth worrying about. So Td5 nearly sorted for the Pyrenees then! CU Quote Link to comment Share on other sites More sharing options...
JST Posted April 10, 2007 Author Share Posted April 10, 2007 So Td5 nearly sorted for the Pyrenees then! No not really, was just going to fill it up and go from there..... Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 10, 2007 Share Posted April 10, 2007 No not really, was just going to fill it up and go from there..... That reminds me then, you packing the towrope, or i Quote Link to comment Share on other sites More sharing options...
JST Posted April 10, 2007 Author Share Posted April 10, 2007 Cheers for the vote of confidence Tim! Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 10, 2007 Share Posted April 10, 2007 Was only reading between Dans lines,, in other words, put one.s finger and sort the TD5 !! Quote Link to comment Share on other sites More sharing options...
