bishbosh Posted April 11, 2007 Share Posted April 11, 2007 Does anyone know if the ABS system used on Disco's is the same as that used on classic Rangies? Could I swap an ABS equipped discovery axle for an ABS equipped RRC axle? Quote Link to comment Share on other sites More sharing options...
simonr Posted April 11, 2007 Share Posted April 11, 2007 Don't know if they are identical, but they both work in the same way, with similar sensors. Worst case, you might have to cobble the original sensors into the new axle. Si Quote Link to comment Share on other sites More sharing options...
JST Posted April 11, 2007 Share Posted April 11, 2007 i think the ABS sensors read off the CVs? so if the CVs are the same for both axles (eg tooth gaps on the cv the same distance apart etc) then thats one confirmation. no doubt with LRs past history of scrimping the electircal bits will also be the same. Quote Link to comment Share on other sites More sharing options...
waveydave Posted April 12, 2007 Share Posted April 12, 2007 The ABS system on RRC and Disco is differnt. But i can see no reason why you cant swap RRC and Disco I axles though.Only problem with that sawp would be if you use an early RRC axle on a late Disco or visa versa and there are some differances in radius arms ect. You will also find that you will have to swap over the calipers as RRC and Disco I are differnt due to theway the differnt brakeing systems operate.Cant see any reason the sensors wont swap over between systems though. Quote Link to comment Share on other sites More sharing options...
