Tonk Posted April 27, 2007 Share Posted April 27, 2007 quick question will a disco 200 tdi injection pump fit a 200 tdi defender engine? Quote Link to comment Share on other sites More sharing options...
Jon White Posted April 27, 2007 Share Posted April 27, 2007 Well they're different part numbers, and the front covers are both also different part numbers. Cant really help you other than that! Jon Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 27, 2007 Share Posted April 27, 2007 Until recently I didn't think the TD injector pump would fit/work on the N/A, but it does. I wouldn't be surprised if it fits to be honest. Les. Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2007 Share Posted April 27, 2007 Yes it will fit, both variants use the same gasket between pump & timing case, so the stud spacings are identical all these parts are same on both Defender & Discovery 200Tdi engines timing belt pulley ERR687, pulley retainer plate ERR359, pump to pulley & pump to timing case nuts FN108041L, banjo bolts for fuel feed & boost pipe connections ERR1125 & ERR886 respectivly, rear brackets are different --use your existing brackets & tighten their bolts up last. injection pipe adaptors are same too. hth Quote Link to comment Share on other sites More sharing options...
