eddie c Posted May 8, 2007 Share Posted May 8, 2007 I'm about to blank my EGR valve. I've read all the posts regarding this subjuct. but my valve has water pipes attached to it. What do I do with the pipes? ED Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 8, 2007 Share Posted May 8, 2007 Are you sure? It might have vacuum pipes but if it has water pipes that is a new one on me Can you post a pic? Also what engine is fitted (may be self explanatory from the picture of course!) Quote Link to comment Share on other sites More sharing options...
eddie c Posted May 8, 2007 Author Share Posted May 8, 2007 will get some photos in the morning. It has a branch coming off the bottom radiator hose which goes to a unit attached to the EGR, then a pipe coming off that and goes under the black rubber engine cover. Quote Link to comment Share on other sites More sharing options...
Cheradenine Posted May 9, 2007 Share Posted May 9, 2007 I'm about to blank my EGR valve. I've read all the posts regarding this subjuct. but my valve has water pipes attached to it. What do I do with the pipes?ED I seem to remember that the later TD5 engines had some kind of cooler attached to the EGR - I guess the pipes you are referring to are for this. Hang on, I'll look it up... --David Quote Link to comment Share on other sites More sharing options...
imspanners Posted May 9, 2007 Share Posted May 9, 2007 I think some of the Japanese imports may have them. You leave the valve in place, just put the blanking plates between the EGR valve and manifold. That way the water pipes are not affected. Quote Link to comment Share on other sites More sharing options...
black-ibex Posted May 9, 2007 Share Posted May 9, 2007 If you are talking about a Td5, then later Euro III models have a cooler built in to the EGR pipe. If you are removing the EGR completely, then simply shorten the top water pipe and join it to the bottom one. Quote Link to comment Share on other sites More sharing options...
eddie c Posted May 10, 2007 Author Share Posted May 10, 2007 Are you sure? It might have vacuum pipes but if it has water pipes that is a new one on me Can you post a pic? Also what engine is fitted (may be self explanatory from the picture of course!) It's a 300TDI Jap import Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 13, 2007 Share Posted May 13, 2007 Amazing. Never seen anything like that here. What will the little yellow men think of next? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 13, 2007 Share Posted May 13, 2007 Amazing. Never seen anything like that here. What will the little yellow men think of next? Water cooled fairleads? Quote Link to comment Share on other sites More sharing options...
RRX Posted May 14, 2007 Share Posted May 14, 2007 At a guess i would says it might be for warming up the engine a bit quicker but thats the only reason i could think for doing that Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 15, 2007 Share Posted May 15, 2007 The TDV6 in the Discovery 3 has coolant flowing to the EGR valves, I assume to keep the valve cool under sustained high load, not sure really. Quote Link to comment Share on other sites More sharing options...
