jameslwt Posted May 14, 2007 Share Posted May 14, 2007 How easy is it to retro-fit a sunroof to a 1996 defender? I haven't taken the head lining down yet, so don't know about stiffening ribs. Are there any at the front? Cheers James (why am I asking this when it's raining!! ) Quote Link to comment Share on other sites More sharing options...
headhunter Posted May 14, 2007 Share Posted May 14, 2007 How easy is it to retro-fit a sunroof to a 1996 defender? I haven't taken the head lining down yet, so don't know about stiffening ribs. Are there any at the front?Cheers James (why am I asking this when it's raining!! ) James Is this so you can lassoo your winch line to the shore when stranded in water? Seriously check the outside to see if there are any rivets where you would expect ribs to be. A new headlining is required to finish the job properly along with an internal plastic trim that fits to the inside of the sunroof and holds the headlining around the sunroof surround. John Quote Link to comment Share on other sites More sharing options...
michael calvert Posted May 14, 2007 Share Posted May 14, 2007 JamesIs this so you can lassoo your winch line to the shore when stranded in water? Seriously check the outside to see if there are any rivets where you would expect ribs to be. A new headlining is required to finish the job properly along with an internal plastic trim that fits to the inside of the sunroof and holds the headlining around the sunroof surround. John unless you have one kicking around it may be as cheap to replace the roof, i picked up a county roof with f&R headlining alpne lights and sunroof for £100, by the time you get a new front lingin £25/30, sunroof £40 it soons adds up plus you might get £30+ for your roof replacing roof isnt much of a job complared to f**kin about fitting one, if however though you got that route use a thick marker to draw round the glass where sunroof goes, that will give you the tollerance for your rubber seal. Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 14, 2007 Share Posted May 14, 2007 personally I wouldn't bother. I had one on the 50th and it used to get on my nerves. Used to collect condensation overnight and then it would drip on your head/face once you get going Cheers Steve Quote Link to comment Share on other sites More sharing options...
mpb Posted May 14, 2007 Share Posted May 14, 2007 personally I wouldn't bother. I had one on the 50th and it used to get on my nerves. Used to collect condensation overnight and then it would drip on your head/face once you get going Im with Steve on this one,dont bother. Many a winter mornig ive got out & it looks like ive p****d myself because its dripped on my trouser. A 1996 Defender has a center rib, that needs to be cut to allow the sunroof to be fitted. Quote Link to comment Share on other sites More sharing options...
jameslwt Posted May 14, 2007 Author Share Posted May 14, 2007 Im with Steve on this one,dont bother. Many a winter mornig ive got out & it looks like ive p****d myself because its dripped on my trouser.A 1996 Defender has a center rib, that needs to be cut to allow the sunroof to be fitted. Cheers guys Think I'll forget about that one then! James Quote Link to comment Share on other sites More sharing options...
