Lars L Posted May 30, 2007 Share Posted May 30, 2007 Is there any difference in size of propshaft flanges between a transfer box for a Td5 Defender compared to the present one in my old One Ten? After engine change to a 200Tdi, it's undergeared and I have found a box at a reasonable cost. So, will my props fit the newer box? Quote Link to comment Share on other sites More sharing options...
HoSS Posted May 30, 2007 Share Posted May 30, 2007 Is there any difference in size of propshaft flanges between a transfer box for a Td5 Defender compared to the present one in my old One Ten?After engine change to a 200Tdi, it's undergeared and I have found a box at a reasonable cost. So, will my props fit the newer box? I'm 97% sure they are the same. (Disco 2 flanges are bigger on the front certianly) Quote Link to comment Share on other sites More sharing options...
Lars L Posted May 30, 2007 Author Share Posted May 30, 2007 That was what I thought (and hoped) too. Quote Link to comment Share on other sites More sharing options...
simonb Posted May 30, 2007 Share Posted May 30, 2007 Is there any difference in size of propshaft flanges between a transfer box for a Td5 Defender compared to the present one in my old One Ten?After engine change to a 200Tdi, it's undergeared and I have found a box at a reasonable cost. So, will my props fit the newer box? Erm, all Defender and Ninety/One Ten transfer boxes are 1.4 ratio unless you had a 2.5 petrol which IIRC was 1.6 so fitting a Td5 transfer won't make any difference. I'm assuming ur old engine was a 2.5 NA or TD, and since the Tdi is a lot more powerful, it shoudn't feel "undergeared". Have you got all the fuel/ boost/ air plumbing correctely set up on ur Tdi? Quote Link to comment Share on other sites More sharing options...
Lars L Posted May 30, 2007 Author Share Posted May 30, 2007 The old engine was (still is ) indeed a 2,5 NAD. With that comes a 1,67 transfercase. The Td5 version is, like all diesel Defenders 1,41. The revs at approx 55 mph (legal speed limit on many roads here) is almost 3000 now, will drop to something around 2500 with the newer transfer. And make first gear useful again. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 30, 2007 Share Posted May 30, 2007 But did not the input splines change at one point?? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 30, 2007 Share Posted May 30, 2007 ...like all diesel Defenders 1,41. Current models are 1.211 Quote Link to comment Share on other sites More sharing options...
Lars L Posted May 31, 2007 Author Share Posted May 31, 2007 Current models are 1.211 Could well be, too modern for me... Quote Link to comment Share on other sites More sharing options...
