jericho Posted June 20, 2007 Share Posted June 20, 2007 This morning I arrived at work and turned the landrover off with the key.I noticed it took a moment for the engine to cut out,which its never done before. Made several journeys throughout the day and it seamed to get slightly worse.This evening there is a delay of about two seconds between turning the key and the engine dying. Its not a problem at the moment,but I suspect it will become one. What is going on?What should I look at? Thanks, Jerry. Quote Link to comment Share on other sites More sharing options...
ciderman Posted June 20, 2007 Share Posted June 20, 2007 Fuel solenoid in the pump , Probbaly the plunger seal worn. Quote Link to comment Share on other sites More sharing options...
western Posted June 20, 2007 Share Posted June 20, 2007 Probably a sticky plunger or weak spring or at the very worst take the shut off solenoid out & see if there's any very thin slithers of swarf in the recess, if there is, you'll need to get the pump rebuilt, it's how the cam plate & roller pick up on each other & wear. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 21, 2007 Share Posted June 21, 2007 Worst case, you could have oil burning in the cylinders Mo Quote Link to comment Share on other sites More sharing options...
