joopkeizer Posted July 1, 2007 Share Posted July 1, 2007 Dear members, I have a 1973 Sovereign Internationl 31' GVWR 7100 Lbs and want to buy a Landrover Defender 130 2007 to pull it. Because the Airstream will stay original I need to where I can find a US tow Hitch with WD (weight distribution) for this jeep Many thanks for your reply, Joop Keizer Quote Link to comment Share on other sites More sharing options...
western Posted July 1, 2007 Share Posted July 1, 2007 If your in the UK, the standard 130 tow hitch mounting will be fine as a USA type hitch is not legal for UK use, if your in Europe or USA you'll have to comply with the relevant regulations as well. not sure what you mean by the weight distribution part ? Quote Link to comment Share on other sites More sharing options...
Old Spot Posted July 1, 2007 Share Posted July 1, 2007 Dont try using a 50mm european hitch if your Airstream has the 2" us coupling, it goes on fine but comes off fine somewhere along the road! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 2, 2007 Share Posted July 2, 2007 This what he is talking about. http://www.etrailer.com/faq/aboutwd.asp You pretty much need a class 4 receiver and then you could mail order the hitch parts. Probably tough to get a receiver hitch in the UK as they use those silly plow shaped things on the back. http://www.trailersnhitches.com/receiverhitchindex.htm http://trailersnhitches.com/putnam/hitchac.../weightdist.htm You could probably mail order a receiver from the States, but as stated, it probably is not legal in the UK. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 2, 2007 Share Posted July 2, 2007 ... and a Land Rover defender 130 is not a Jeep Mo Quote Link to comment Share on other sites More sharing options...
western Posted July 2, 2007 Share Posted July 2, 2007 aH, got it now, what's known in the UK as a anti-sway or stabiliser, UK ones look like a single leaf spring anchored at the vehilce end & sits on a slipper pad at the trailer drawbar end. Quote Link to comment Share on other sites More sharing options...
