bobonacus Posted July 7, 2007 Share Posted July 7, 2007 Hi, I have all the engine to gearbox bolts out except the one by the clutch slave cylinder / start motor Any tips on how to get it out?? I can just get a finger to it but no way get a spanner on it. Do I have to remove the engine mounts and lower the engine to get better access? cheers Robert Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 7, 2007 Share Posted July 7, 2007 Removing the mounts and lowering (as per the manual) gives a lot more room. I think I used a socket with U-joint and some long extensions to reach this one. Some people remove the floor and access from inside the cab. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 7, 2007 Share Posted July 7, 2007 A long extension bar over the top of the downpipe usually does the trick. Les. Quote Link to comment Share on other sites More sharing options...
treebloke Posted July 7, 2007 Share Posted July 7, 2007 A long extension bar over the top of the downpipe usually does the trick.Les. Thats the way to do it, but theres a bit of guess work involved geting the socket in the right place. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 7, 2007 Share Posted July 7, 2007 I used a long extension bar and one of those double jointed sockets, job done Mo Quote Link to comment Share on other sites More sharing options...
bobonacus Posted July 8, 2007 Author Share Posted July 8, 2007 cheers, thats done it Quote Link to comment Share on other sites More sharing options...
