Anorak_Stan Posted July 27, 2007 Share Posted July 27, 2007 Does anybody know where a set of Longer Defender/RR Classic /Disco1 wheel studs (say 12mm-15mm Longer) be obtained from - Hopefully @ a sensible price ? Any ideas or sugestions would be great. Thanks Lyndon Quote Link to comment Share on other sites More sharing options...
gelf Posted July 28, 2007 Share Posted July 28, 2007 try here........ http://www.zeus.uk.com/land-rover.php Quote Link to comment Share on other sites More sharing options...
Jon White Posted July 29, 2007 Share Posted July 29, 2007 Lyndon, Zeus are the only ones I've ever come accross. I've got them on the back of my series - they're not cheap though! Jon Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted July 31, 2007 Author Share Posted July 31, 2007 Lyndon,Zeus are the only ones I've ever come accross. I've got them on the back of my series - they're not cheap though! Jon Jon, Tell Me About It £4.90 each Plus VAT - Are They Gold Plated By Any Chance ? Lyndon Quote Link to comment Share on other sites More sharing options...
Jon White Posted July 31, 2007 Share Posted July 31, 2007 Er yeah that was about what they cost! No they aint gold plated I'm afraid, but i think it becomes a case of needs must - I've never found anybody else who makes them! What are you doing that needs longer studs then? Jon Quote Link to comment Share on other sites More sharing options...
will_warne Posted July 31, 2007 Share Posted July 31, 2007 Zeus - the only company I've come across with a worse business ethic than Scrap Iron racing! As Jon said, why do you need them? Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted August 2, 2007 Author Share Posted August 2, 2007 Er yeah that was about what they cost! No they aint gold plated I'm afraid, but i think it becomes a case of needs must - I've never found anybody else who makes them!What are you doing that needs longer studs then? Jon Well, Here's The Story - I've decided to get rid of My "Carlos Fandango" MACH 5's as I want to change to 16" Tyres form My 15" Tyres so I couldn't find any 16" MACH 5's (Let alone with the right offset) so decided to go for "Standard" LR Alloys but of course the offset is no-where near that of My Special MACH 5's so Spacers were required to get my "Correct" offset back. Had custom Spacers made for My desired offset but when I fitted them I decided I didn't have enough turns of the nut to hold them onto the Axle hnce 10-155mm Longer wheelstuds were wanted. However no I've decided to change the plan alittle and get the spacers modified to accept "Standard" LR Alloy Wheel nuts as that will give me the correct fitment of the nuts etc without having to lose any metel / strength from the spacers ! Lyndon By the Way anybody got a set of LR Alloy Wheel Nuts Going Cheap ! ! ! ! ! Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 2, 2007 Share Posted August 2, 2007 Ah I see!!! I've got a set of alloy nuts you can have for a drink - you know where to find me! Cheers Jon Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted August 3, 2007 Author Share Posted August 3, 2007 Ah I see!!!I've got a set of alloy nuts you can have for a drink - you know where to find me! Cheers Jon Thanks for that Jon, I may well "Annoy You" in the next few days. Lyndon Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 3, 2007 Share Posted August 3, 2007 No worries - should be around pretty much all weekend but give me a ring on the mobile just to make sure if you're planning to make a special journey. Cheers Jon Quote Link to comment Share on other sites More sharing options...
02GF74 Posted August 3, 2007 Share Posted August 3, 2007 didn't quite follow ^^^ wot you are doing but Rally Design do longer wheel studs; they are ford car aplications so would be smaller diameter I think. Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted August 8, 2007 Author Share Posted August 8, 2007 didn't quite follow ^^^ wot you are doing but Rally Design do longer wheel studs; they are ford car aplications so would be smaller diameter I think. Thanks, Tried them (and Others) but the LR has a M16 x 1.5 Thread and as that is quite large none of the usual suppliers of "Special" wheel studs supply them that large. I have however now finnished and fitted my new spacers (thanks to Jon for the Nuts) and am very happy with the results. Lyndon Quote Link to comment Share on other sites More sharing options...
Jon White Posted August 9, 2007 Share Posted August 9, 2007 What tyres you on now then Lyndon? Cheers Jon Quote Link to comment Share on other sites More sharing options...
Anorak_Stan Posted August 9, 2007 Author Share Posted August 9, 2007 What tyres you on now then Lyndon?Cheers Jon Well, Still on Bronco Grizzly Claw but have changed from My 33 x 12.50 x 15 to 305 x 70 x16 they claim as :(33 x 12.5 x 16) but they are in fact appx .75 inch Narrower so for the East Grinstead site they should work a little better and give me a little more "Bite". May well keep original Mach 5's with there 33 x 12.5 x 15 for Slab etc Will see this weekend when they get there first outing. Lyndon Quote Link to comment Share on other sites More sharing options...
