Discovery brakes
trr777
Yes, sorry I should have mentioned that I have bled out all the air as normal, front and back, even bled the master cylinder, still no good. Have noticed that if you pump brake peddle slowly, brake fluid spits back out of master cylinder resivoir?. Tim.
Hi, just an idea...
how may lines do you have going to the front calipers? 2 or one?
If its got two lines then have you have bled from all three bled nipples on the caliper?
two on the back on each side, and one on the top facing into the car. I have found that bleeding all three at the same time is the best way..
If you have tried this then ignore me :) just a lot of people don't realize there are three bled point on the front calipers....
hope this helps
