Gromit Posted August 3, 2007 Share Posted August 3, 2007 ok, so I recently put in britpart's +2" springs in in the 110. The front is grand, the back is up about 2 1/2". They're good off road, as it keeps the rear hitch clear of most things, but empty, on-road they are just too stiff. Bumpy C-roads are just nightmareishly bumpy, and makes the whole experience VERY unpleasant. So, they have to go. I still would like to keep the lift, but lifted using a longer spring rather than stiff one IYSWIM. Any recommendations? Th-th-th-th-th-th-th-thank y-y-y-y-y-y-y-ou Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 3, 2007 Share Posted August 3, 2007 Land Rover heavy duty front Land Rover heavy duty on the rear with 130 helper springs. You'll certainly get the lift from that. I like the road manners full or empty. mike Quote Link to comment Share on other sites More sharing options...
q-rover Posted August 3, 2007 Share Posted August 3, 2007 Air suspension Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 3, 2007 Share Posted August 3, 2007 http://members.shaw.ca/jbarge/springinfo.html Can't see brit part on there, but if you can find the length and piounadge the enclosed above could help at lot ! Nige Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 3, 2007 Author Share Posted August 3, 2007 Land Rover heavy duty on the rear with 130 helper springs. HFH, thanks for that. Mike, do you have any suppliers? Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 3, 2007 Share Posted August 3, 2007 Land Rover...... Sorry that's all I have. The 130 helper springs came second hand as I had hoped the would have eased a bit. No such luck. It would have been cheaper to buy the springs and source the plates second hand. They were 22 quid each. Four needed. Have a look here how I did the rears... http://www.landroveraddict.com/smf/index.php?topic=358612.20 mike Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 3, 2007 Author Share Posted August 3, 2007 Land Rover...... Sorry that's all I have.The 130 helper springs came second hand as I had hoped the would have eased a bit. No such luck. It would have been cheaper to buy the springs and source the plates second hand. They were 22 quid each. Four needed. Have a look here how I did the rears... http://www.landroveraddict.com/smf/index.php?topic=358612.20 mike Thanks for that. The retaining plates certainly make it an expensive option. Are 110 helpers (which is all I can see on Craddocks) the same as 130 helpers? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 3, 2007 Share Posted August 3, 2007 Thanks for that. The retaining plates certainly make it an expensive option.Are 110 helpers (which is all I can see on Craddocks) the same as 130 helpers? yes, they are. a year or two ago, it seemed that every other stall at sodbury/billing were selling the little adaptor plates, but now i want some, no one's got them! I think there must have been a large disposal from the MoD (possibly when they got rid of the 130" rapiers?) so they sold off the old stock. just like at the moment, do an ebay search for "salisbury axle" and quite of the suppliers are selling brand new, in the crate, disk braked salisbury rears for about £500, obviously the MoD are chucking a few away! Quote Link to comment Share on other sites More sharing options...
Phoenix_chris Posted August 6, 2007 Share Posted August 6, 2007 Just as a suggestion, try the Bearmach OR springs, not the Heavy Duty ones, i think its BA 2255 for the front but cant remember for the rear, we sell loads and they give great results... without shaking you to bits Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 7, 2007 Author Share Posted August 7, 2007 thanks guys 'n' galls. Seems the boge strut was seizing, which was stiffening everything up. Attacked it with the grinder yesterday and it's a lot better now, so will stay with the existing setup and see how we go. Quote Link to comment Share on other sites More sharing options...
