Mark Posted August 16, 2007 Share Posted August 16, 2007 Ok, I have to fit a new hose between the power steering pump and the steering box tonight. Do I need to bleed it once I have it all connected up? I presume I do, so can anyone give me some pointers? Ta Mark Quote Link to comment Share on other sites More sharing options...
mmgemini Posted August 16, 2007 Share Posted August 16, 2007 I just fill the resevoir up. Start the engine, let it tick over and move the steering wheel lock to lock. Bet you ten bob somebody says it warong mike Quote Link to comment Share on other sites More sharing options...
LR90 Posted August 16, 2007 Share Posted August 16, 2007 Worked for me too Quote Link to comment Share on other sites More sharing options...
stumpy2268 Posted August 16, 2007 Share Posted August 16, 2007 Mark, You can open the bleed nipple on the steering box if you wish - so it says in the manual. You will probably only get the odd bubble of air from the box, and succeed in dribbling fluid all over the place however. Lock to lock works for me too, having tried both methods. Adrian. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 16, 2007 Share Posted August 16, 2007 I just fill the resevoir up. Start the engine, let it tick over and move the steering wheel lock to lock. 's what the book says. I have also managed to get a few bubbles out of the nipple. Chris Quote Link to comment Share on other sites More sharing options...
stumpy2268 Posted August 16, 2007 Share Posted August 16, 2007 Mark,You can open the bleed nipple on the steering box if you wish - so it says in the manual. You will probably only get the odd bubble of air from the box, and succeed in dribbling fluid all over the place however. Lock to lock works for me too, having tried both methods. Adrian. Quote Link to comment Share on other sites More sharing options...
Mark Posted August 16, 2007 Author Share Posted August 16, 2007 Cool, that sounds easier than I was expecting. thanks chaps. Mark Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 16, 2007 Share Posted August 16, 2007 Yep, fill it up and cycle it a few times until the pump quietens down. Quote Link to comment Share on other sites More sharing options...
