mwoodpower Posted August 22, 2007 Share Posted August 22, 2007 does any one know the mph in 5th revs per minute for both standard and high ration transfer boxes, and does it make a big difference at motorway speeds ie noise and mpg cheers mark Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 22, 2007 Share Posted August 22, 2007 I don't know the figure you refer to but all Td5 Defender transfer boxes are 1.4:1 as far as I am aware, there isn't a "high ratio" option at least not from the factory (though I am sure many people have fitted the 1.22:1 box out of a Discovery) Quote Link to comment Share on other sites More sharing options...
mwoodpower Posted August 22, 2007 Author Share Posted August 22, 2007 yes i mean the box out of a disco Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 22, 2007 Share Posted August 22, 2007 1.41 = 72 mph at 3000 rpm 1.22 = 83 mph @ 3000 rpm on regular 32" tyres. Quote Link to comment Share on other sites More sharing options...
Litch Posted August 22, 2007 Share Posted August 22, 2007 Makes a very worthwhile conversion on my 300TDi 90 and I thoroughly recomend it but you should really try and take a spin in a converted TD5 before making your mind up. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted August 23, 2007 Share Posted August 23, 2007 Makes a very worthwhile conversion on my 300TDi 90 and I thoroughly recomend it but you should really try and take a spin in a converted TD5 before making your mind up. If 'converted' [from 1.4 to 1.2] does a Defender Td5 have greatly reduced towing capability? My 110 does 90% non towing, but I do need it for towing car trailers with other landies on, and am also considering a 5 berth double axle caravan. Does putting a 1.2 transfer box in make the Defender like a Td5 Disco to tow with ? My transfer box is a real whiner, so will be swapping it for a recon box from Ashcroft, and as I feel that at 60mph I need to change in to 'sixth gear' am considering the 1.2 gearing. Quote Link to comment Share on other sites More sharing options...
mwoodpower Posted August 24, 2007 Author Share Posted August 24, 2007 i have just had the high ratio box fitted, not only quieter (than my 175k box) but also smoother, the new gearing takes a little bit to get used to spending longer in 4th than before, but once into 5th she realy flies, felling much more relaxed. when towing a heavy trailer i would keep in 4th alot, for hills but still has loads of power there. if you spend only 10% towing i would recomend , also had new gearbox at same time as the old one gave in, so i may just feel impressed with the whole new setup. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted August 24, 2007 Share Posted August 24, 2007 i have just had the high ratio box fitted You mean lower ratio. the Discovery hi range is a lower ratio (1.2) than a defender hi range (1.4) Hi range = low ratio Lo range = High ratio Quote Link to comment Share on other sites More sharing options...
