ROGUE TROOPER Posted October 29, 2005 Share Posted October 29, 2005 ...Stick with my std 3.5 EFi in my 2A or...... Fit the 3.9 EFi with Twin plenum? The poor thing needs some TLC as the gearbox is on its way out (2A box) and it realy needs a rewire. mmmm what should I do? Quote Link to comment Share on other sites More sharing options...
fisha Posted October 29, 2005 Share Posted October 29, 2005 stick in the twim plenum and give me the old EFI? no? awww how not? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 29, 2005 Share Posted October 29, 2005 What's the difference between 3.5 EFi and 3.9 EFi then? Only thing I can see worth worying about is the later one uses "normal" injectors not nasty barbed ones. Surely you can just lob the twin flem chamber onto the 3.5 setup. Quote Link to comment Share on other sites More sharing options...
selectcase Posted October 29, 2005 Share Posted October 29, 2005 Stick with the standard and sell the 3.9, do you really want all that hassle again Quote Link to comment Share on other sites More sharing options...
ROGUE TROOPER Posted October 29, 2005 Author Share Posted October 29, 2005 3.9 has 400 more cc The intention is to keep all the 3.5 EFi electronic stuff as its already set up as the Twin Plenum is 3.5 anyway! Im using a Jag AFM as its bigger, but the intention is to convert to Megasquirt! :) Quote Link to comment Share on other sites More sharing options...
minivin Posted October 30, 2005 Share Posted October 30, 2005 What's the difference between 3.5 EFi and 3.9 EFi then? Only thing I can see worth worying about is the later one uses "normal" injectors not nasty barbed ones. Surely you can just lob the twin flem chamber onto the 3.5 setup. OT FF, but I recognised your Avatar not quite Watership Down Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2005 Share Posted October 30, 2005 3.9 has 400 more cc The intention is to keep all the 3.5 EFi electronic stuff as its already set up as the Twin Plenum is 3.5 anyway! Im using a Jag AFM as its bigger, but the intention is to convert to Megasquirt! :) A 3.9 engine has 400 more cc but the injector flow rate is no different IIRC, what are you gaining? Jag AFM will have the wrong fuel curve in it, yes it flows more air but if the mixture's cocked you could have other problems. Rob - was wondering if anyone would recognise it Quote Link to comment Share on other sites More sharing options...
