JST Posted October 2, 2007 Share Posted October 2, 2007 What do we all reckon - woudl a TD air filter and housing provide sufficient air flow for a tdi engine? Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2007 Share Posted October 2, 2007 Most likely, but I'd use the correct parts if available. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted October 2, 2007 Share Posted October 2, 2007 And if you could.... (Sorry JST.. Not trying to hijack, just wonder if people can answer both in one....) Would a 300TDi airbox be good enough for a 3.9 V8? (Part number ESR2102) (Ralph.. Trash if I've been a naughty boy..) Neil Quote Link to comment Share on other sites More sharing options...
JST Posted October 3, 2007 Author Share Posted October 3, 2007 no problem Neil. Ralph its a disco tdi going (well gone) into a Def and theres no room for the tdi air filter box (not where i want it anyway) but the TD one will fit! Quote Link to comment Share on other sites More sharing options...
western Posted October 3, 2007 Share Posted October 3, 2007 Try it & can't see why it shouldn't work, both engines would draw the same amount of air as they are the same cubic capacity. Neil, as above try it. Quote Link to comment Share on other sites More sharing options...
JST Posted October 3, 2007 Author Share Posted October 3, 2007 cheers ralph, will give it a go and see what happens. same capacity but one has an intercooler and higher (?) pressure turbo so isint the air compressed more so therefore more air goes in to the cylinder? therefore it needs to draw more air??? a turbo 2.5 certainly draws more air than a N/A Quote Link to comment Share on other sites More sharing options...
western Posted October 3, 2007 Share Posted October 3, 2007 cheers ralph, will give it a go and see what happens. same capacity but one has an intercooler and higher (?) pressure turbo so isint the air compressed more so therefore more air goes in to the cylinder? therefore it needs to draw more air???a turbo 2.5 certainly draws more air than a N/A IIRC the Defender 200Tdi & TD air filter elements are almost the same diameter & length, so I would expect the through flow of air into the engine to be similar. Quote Link to comment Share on other sites More sharing options...
nobber Posted October 3, 2007 Share Posted October 3, 2007 they are different though , funnily enough im looking for a td filter and box and sat in my shed is a disco filter and box that i cant use. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted October 3, 2007 Share Posted October 3, 2007 Try it & can't see why it shouldn't work, both engines would draw the same amount of air as they are the same cubic capacity.Neil, as above try it. The amount of air drawn is higher in a TDI because it is running at higher boost. A TDI at 15 psi versus a TD at 6 psi draws (15 + 14.7) / (6 + 14.7) = 43% more air. Actually a little less due to losses into the cylinders, but that is the ballpark. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted October 3, 2007 Share Posted October 3, 2007 Thanks James and Ralph.... Now to compile a list of required parts for the Classifieds section..... Neil Quote Link to comment Share on other sites More sharing options...
