Coastcard Posted October 4, 2007 Share Posted October 4, 2007 Just doing final tests for MOT. Testing the indicators and flashed about 4 times then stopped (hazards don't work either now). Don't think it is the fuse as stop lights OK and apparently on same fuse, so suspect the relay as the only other common part. When I find the relay I will also double check for 12v But... where is it? Vehicle is an '88 V8 110. Thanks. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted October 4, 2007 Share Posted October 4, 2007 Just doing final tests for MOT. Testing the indicators and flashed about 4 times then stopped (hazards don't work either now). Don't think it is the fuse as stop lights OK and apparently on same fuse, so suspect the relay as the only other common part.When I find the relay I will also double check for 12v But... where is it? Vehicle is an '88 V8 110. Thanks. It's in the fusebox, behind the fuse panel. You'll need to undo the two screws holding the fuse box panel to the bulkhead to enable access to the flasher relay. Paul. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 4, 2007 Share Posted October 4, 2007 The hazard switch itself is a prime suspect too. The indicator wiring goes through it. I diagnosed the fault by waggling the hazard switch up down, left right, varying pressure etc, and watched the indicators flash randomly. Quote Link to comment Share on other sites More sharing options...
Gromit Posted October 4, 2007 Share Posted October 4, 2007 The hazard switch itself is a prime suspect too. ..and it can be disassembled and cleaned up/fettled pretty easily too Quote Link to comment Share on other sites More sharing options...
Coastcard Posted October 4, 2007 Author Share Posted October 4, 2007 It's in the fusebox, behind the fuse panel. Thought it was that one, but wire colours didn't seem to correspond. Dashboard in bits anyway!! The hazard switch itself is a prime suspect too. The indicator wiring goes through it.I diagnosed the fault by waggling the hazard switch up down, left right, varying pressure etc, and watched the indicators flash randomly. Will get wiggling as well Cheers all. Quote Link to comment Share on other sites More sharing options...
headhunter Posted October 4, 2007 Share Posted October 4, 2007 Just doing final tests for MOT. Testing the indicators and flashed about 4 times then stopped (hazards don't work either now). Don't think it is the fuse as stop lights OK and apparently on same fuse, so suspect the relay as the only other common part.When I find the relay I will also double check for 12v But... where is it? Vehicle is an '88 V8 110. Thanks. When my hazards did not work it was the fuse. John Quote Link to comment Share on other sites More sharing options...
Coastcard Posted October 4, 2007 Author Share Posted October 4, 2007 Twas the relay. Phew - thanks all. Quote Link to comment Share on other sites More sharing options...
