russ3120 Posted October 12, 2007 Share Posted October 12, 2007 Gents looking to fit some onboard air to the disco when i have finished the reshape, what sort do you recommend? I want to be able to inflate my tyres, use air tools and eventually fit to lockers thanks in advance Russ Quote Link to comment Share on other sites More sharing options...
landrover598 Posted October 12, 2007 Share Posted October 12, 2007 Have a look here for a good setup Quote Link to comment Share on other sites More sharing options...
russ3120 Posted October 12, 2007 Author Share Posted October 12, 2007 Have a look here for a good setup thanks Dave was look at something a little less complicated to do Quote Link to comment Share on other sites More sharing options...
landrover598 Posted October 12, 2007 Share Posted October 12, 2007 Well you've seen my very basic setup, an electric compressor filling a small tank, a few fittings, pressure switch and an airline connection. Quote Link to comment Share on other sites More sharing options...
russ3120 Posted October 12, 2007 Author Share Posted October 12, 2007 Well you've seen my very basic setup, an electric compressor filling a small tank, a few fittings, pressure switch and an airline connection. does it run air tools? will take a closer look next time i BIATCH for you Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 12, 2007 Share Posted October 12, 2007 I think you'll need a pretty big air tank to run air tools off an electric compressor, unless its huge. an air con compressor on the other hand has high enough output that it won't need a big tank. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted October 13, 2007 Share Posted October 13, 2007 does it run air tools? No, I'm happy to use hand tools, and dont want the extra weight of a big tank and rattle gun. Quote Link to comment Share on other sites More sharing options...
Diff Posted October 14, 2007 Share Posted October 14, 2007 My simplified on board air system: http://forums.lr4x4.com/index.php?showtopic=13723 Regards, Diff Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 14, 2007 Share Posted October 14, 2007 A cost effective option is to use a T-max Heavy Duty compressor. You could simply install with a fused feed straight from battery. A number of people on here are using them. To run air tools you'd need to install a tank to get an ok flow rate. A regulator can be used for the feed to locker/s. Won't be as cheap as other options, but if you want simple here's a link to what I did. Viair Onboard air kit I fitted a 100% duty cycle Viair onboard air kit, that cost about 230 pounds IIRC. Cheers Steve Quote Link to comment Share on other sites More sharing options...
