JST Posted October 26, 2007 Share Posted October 26, 2007 Thinking about wiring my heated front screen into the same switch that does the heated rear screen. Then using the 'on' feed from the HRW switch to switch a relay for the front screen. However reading other posts on here i reckon i probably need a timer of some sort on the HFS side of things so the screen doesn't burn its self out. So can you get Relays with timers combined in them? if not where would you get a 'normal' timer from and finally how long should the front screen run for, (5-8mins seems average off the HFS i have tried at work etc) I would like the timer in case i forget to turn off the rear screen and so i can put the rear screen on and leave it on rather than just 'remembering' to turn it off myself! Quote Link to comment Share on other sites More sharing options...
white90 Posted October 26, 2007 Share Posted October 26, 2007 heated rear window has an 8min timer IIRC or part number YWB10012L Freelander heated screen relay £5ish Quote Link to comment Share on other sites More sharing options...
TJ101 Posted October 26, 2007 Share Posted October 26, 2007 Am sure you will find a "timer" relay, here amongst the collection, if you look hard enough, OK, may say Volvo on it !! Quote Link to comment Share on other sites More sharing options...
ex_mod_90 Posted October 26, 2007 Share Posted October 26, 2007 Hi, I used GLR10 from http://www.vehicle-wiring-products.eu/VWP-...lays/timers.php on my heated windscreen project. Works a treat. Push button to turn on the screen, auto off after 10 minutes. Rich. Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2007 Share Posted October 26, 2007 James, I've got a ex-RRC timer/relay for a front heated screen here, I'm not using it as I've got the correct Defender version. yours if you want it. Quote Link to comment Share on other sites More sharing options...
JST Posted October 26, 2007 Author Share Posted October 26, 2007 Ralph, sounds ideal, how much would you like and could you pop it in the post or are you passing Taunton in the near future? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 26, 2007 Share Posted October 26, 2007 James, I've got a ex-RRC timer/relay for a front heated screen here, I'm not using it as I've got the correct Defender version. yours if you want it. Ralph, could you post up the part # for the defender version? any idea how it differs from the RR one? Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2007 Share Posted October 26, 2007 RRC one I have here is grey with a blue label part number PRC6796 it has 5 spade terminals, how does 10 quid sound, IIRC thats about what I paid for it from ebay, same place as the link below. the Defender one I'm using is PRC7303, mine is actually a Hella 4ra 12v 003 510-46. this is a 4 terminal unit.paid 14.55 inc vat/postage for this one. 1 here on ebay JST can post it on monday if you want it Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 26, 2007 Share Posted October 26, 2007 Thanks Ralph. something else to get ready for my 110! Quote Link to comment Share on other sites More sharing options...
JST Posted October 27, 2007 Author Share Posted October 27, 2007 Ralph, sounds ideal are you happy to post? i can send a chq or give you the cash if you are passing. Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2007 Share Posted October 27, 2007 PM heading your way. Quote Link to comment Share on other sites More sharing options...
