tomj Posted October 28, 2007 Share Posted October 28, 2007 Hi I am busy restoring (returning to the road......!!) a 1980 series 3 88inch I have refit the rear body after chassis repairs and that has bolted down and fit where it should, it has joined in line wiht the sill panels etc.... However, on fitting the doors there does not seem to be enough room to close them - do they have any adjustment? (they are the newer defender type hinges) Has anyone else experienced this problem?? Also this landy is dark grey - were they produced in dark grey from the factory? Cheers Quote Link to comment Share on other sites More sharing options...
rtbarton Posted October 29, 2007 Share Posted October 29, 2007 The way I fitted mine was to loosen the hinge bolts, tub bolts and bulkhead bolts and move everything round like a jelly until it all lined up and then tightened everything before it moved. I haven't tried fitting the roof yet though! Quote Link to comment Share on other sites More sharing options...
RobotMan Posted October 29, 2007 Share Posted October 29, 2007 Big Hammer! Last time I had mine apart for a rebuild I had to use quite an amount of shim from the chassis front tub mounts to leave enough gap for the doors. There is some play on the hinges if you loosen all the screws but this only helps if the hole is big enough for the door. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 29, 2007 Share Posted October 29, 2007 Is it the windscreen tilt that is stopping them close? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 30, 2007 Share Posted October 30, 2007 Loosen everything, get it all lined up and then tighten it up again! Depending what you've been doing, if the back end is reasonably unchanged then get the tub bolted in so t he rear X-member is holding it square, then line everything up working forwards. If you've had the bulkhead off, that has some jiggle in it too which will obviously affect the doors (among other things). Quote Link to comment Share on other sites More sharing options...
tomj Posted October 30, 2007 Author Share Posted October 30, 2007 Thanks for all the ideas guys I loosened the front of the rear tub and shimmed it up a bit on the front mounts - i also had to loosen all the hinges and wiggle about until i got them to close Thanks a lot Tom Quote Link to comment Share on other sites More sharing options...
