Driftwood Posted November 8, 2007 Share Posted November 8, 2007 With the TD5 tank that I have I've been given the pump as well, but will this have enough pressure for a 3.9EFi? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 8, 2007 Share Posted November 8, 2007 With the TD5 tank that I have I've been given the pump as well, but will this have enough pressure for a 3.9EFi? Doubtful. It should work as a lift-pump though, then use an inline pump from a Jag/Golf/Cavalier/Etc to feed the EFi. I run a similar setup (plus a swirl-pot) and it works well. The inline pumps can be had for around £30 on ebay. Quote Link to comment Share on other sites More sharing options...
Driftwood Posted November 8, 2007 Author Share Posted November 8, 2007 Thanks Fridgefreezer. Your all so helpful on this forum, so beware cause I have millions of questions Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 8, 2007 Share Posted November 8, 2007 The efi pump puts out about 30psi or 2 bar, the TD5 pump puts out 60psi or 4bar. But it will have to be piped in properly with the low and high pressure stages. RTFM. Quote Link to comment Share on other sites More sharing options...
nas90 Posted November 8, 2007 Share Posted November 8, 2007 Thanks Fridgefreezer.Your all so helpful on this forum, so beware cause I have millions of questions I have a spare tank pump from the nas if it fits a TD5 tank some beer vouchers will be sufficient BTW the nas has a rear mounted under floor plastic tank between the chassis rails Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 8, 2007 Share Posted November 8, 2007 The efi pump puts out about 30psi or 2 bar, the TD5 pump puts out 60psi or 4bar. But it will have to be piped in properly with the low and high pressure stages. RTFM. And I thought TDi's created the high pressure in the injection pump on the engine what are these low & high pressure stages? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 9, 2007 Share Posted November 9, 2007 The efi pump puts out about 30psi or 2 bar, the TD5 pump puts out 60psi or 4bar. But it will have to be piped in properly with the low and high pressure stages. RTFM. And I suspect a Td5 pump will not last long pumping petrol and/or may result in a colossal kaboom Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 9, 2007 Share Posted November 9, 2007 If it would help I'll get the crayons out and post up my fuel system (out of tank pump EFi setup) which I've arrived at through a bit of trial and error. Quote Link to comment Share on other sites More sharing options...
