Bumpyride Posted November 15, 2007 Share Posted November 15, 2007 The clutch and gearbox have been working fine during the rebuild, however took it for a quick spin to test the brakes and have returned and can't select reverse gear. I would argue that the clutch is a bit heavy, but not impossible. Anybody know of thingsi should be checking prioir to taking the thing out again? Quote Link to comment Share on other sites More sharing options...
kiall Posted November 15, 2007 Share Posted November 15, 2007 the reverse spring/stop wind it out a bit or totally to check Quote Link to comment Share on other sites More sharing options...
white90 Posted November 15, 2007 Share Posted November 15, 2007 reverse lamp switch screwed in to far Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 15, 2007 Author Share Posted November 15, 2007 sorry haven't got a gear box R380 manual where is the spring stop located? If anybody has one then please can i have the link. Quote Link to comment Share on other sites More sharing options...
kiall Posted November 15, 2007 Share Posted November 15, 2007 Opps thought it was a lt77 dont know if its the same if it is it will be at the base of the gearstick Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 16, 2007 Author Share Posted November 16, 2007 ok have undown the reversing switch a turn or two, no effect, so removed completely still no effect. When moving the gear stick i can't actually move across enough to then be in a position to select a gear To note it is an LT77 gear box, (had one or two different engines in this one) where is the reversing switch spring adjustment? anybody have an experience with altering this? IF this fails to work does anybody has any possible causes, to note it had been working perfectly 5 mins before Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2007 Share Posted November 16, 2007 could be the 5th gear stop is causing the problem Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 16, 2007 Author Share Posted November 16, 2007 sorry can i just check the reverse spring/stop mentioned by Kiall, is this the same as the fifth gear adjustment or is this a mistaken reference to the reversing switch. Or is it something different again. Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2007 Share Posted November 16, 2007 nope, 5th gear stop & revverse light switch are 2 different things. Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 16, 2007 Author Share Posted November 16, 2007 sorry didn't make that clear is the reverse spring/stop mentioned by Kiall The same as A: the reverse switch - ie stop due to limit of switch plunger. or B: the fifth gear adjustment- screw or C: neither? What i was wondering is there 2 adjustment options - 1 for fifth gear and also independantly for reverse gear. sorry for any confusion Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2007 Share Posted November 16, 2007 reverse switch if screwed in to far would affect the reverse selection movement, the 5th gear stop wouldn't. Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 23, 2007 Author Share Posted November 23, 2007 Just for future infomation i have contacted the extremely helpful David Ashcroft an he has said that the problem will be the reverse gear plunger sticking, which requres the removal of the plate on the side of the gearbox turret (2*13mm headed blots), followed by removal of the plunger, a good clean and re-fitting. If anybody has experience of this job any handly hints are always appreciated Quote Link to comment Share on other sites More sharing options...
freeagent Posted November 23, 2007 Share Posted November 23, 2007 I reckon your best bet is to scrap it if the plunger trick fails... The other possiblity is a tree might have grown up between the chassis rails where it has been standing so long... ...or your Dad has nobbled it in the hope you will scrap it and get it off his garden... Quote Link to comment Share on other sites More sharing options...
Bumpyride Posted November 23, 2007 Author Share Posted November 23, 2007 Ah not much cooking today then. Just you wait (posisbly for a quite a while) by the time i've finished ill have removed and replaced every dam part. Quote Link to comment Share on other sites More sharing options...
freeagent Posted November 23, 2007 Share Posted November 23, 2007 Ah not much cooking today then. Just you wait (posisbly for a quite a while) by the time i've finished ill have removed and replaced every dam part. Got plenty cooking today, on the ragged edge of project management as always... Make sure you leave the door open for a little while before you move it, give the mice a chance to evacuate... Quote Link to comment Share on other sites More sharing options...
