shildonian Posted November 18, 2007 Share Posted November 18, 2007 can any one tell me how to programe a new fob mines damaged i`ve got a replacement but don`t know where to start is it a job for main dealer (m reg 300 tdi) cheers Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 19, 2007 Share Posted November 19, 2007 If it is a two button fob (1996 model year vehicle with TAxxxxxx vin number) then you will need somebody with a Testbook to do it for you. Quote Link to comment Share on other sites More sharing options...
sotal Posted November 19, 2007 Share Posted November 19, 2007 If it's a single button as it should be for a 95 then download the rave CD (search google for free download) and follow the instructions in there Quote Link to comment Share on other sites More sharing options...
RRX Posted November 20, 2007 Share Posted November 20, 2007 i would advise getting a mate to help as otherwise you end us running around the vehicle to get the alarm in the correct mode Quote Link to comment Share on other sites More sharing options...
shildonian Posted November 20, 2007 Author Share Posted November 20, 2007 thanks for your help! chasing up the rave cd angle to see if i can get sorted. some muppet in a tranny took my wing mirror off tonight on the way home so i,m on the look out for a replacement does any one know a breakers in the county durham area who may be able to help me with this one.don,t you just love tranny drivers when there in a hurry! Quote Link to comment Share on other sites More sharing options...
wayneg Posted November 28, 2007 Share Posted November 28, 2007 Does anyone know if I purchase a second hand remote (as a spare) for my 93 RRC can this be programmed to the car along with the original, presumably unless I was unbelievably lucky they would be working on different frequencies. How do I find the correct frequency? Below are the programming instructions I have found, hope they are correct. (It may take several attempts and the timing must be correct for it to work) 1)Starting conditions: ignition off, doors unlocked, bonnet switch depressed. 2)Steps 3 to 9 MUST be carried out within 8 seconds. 3)Switch ignition ON. 4)Switch ignition OFF. 5)Lock doors. 6)Unlock doors. 7)Release bonnet switch. 8)Switch ignition ON. 9)Switch ignition OFF. If alarm is correctly accessed, the horn will sound and LED will light. It is now possible to programme two handsets of correct frequency to vehicle alarm ECU. This must be carried out within two minutes. 10)Press and hold down button on first handset until dash LED flashes. 11)Repeat instruction for second handset. 12)The LED will extinguish if both handsets have been initialised correctly Quote Link to comment Share on other sites More sharing options...
