cols110 Posted November 11, 2005 Share Posted November 11, 2005 OK all, I have a knackered LT77 input shaft that I got from Ashcrofts when I picked up a gear box, that I use as a clutch alignment tool. Now the question is, are the clutch centre`s and input shafts the same or different, will this input shaft work as an alignment tool on all of these gearboxes or just the LT77. Thanks Quote Link to comment Share on other sites More sharing options...
western Posted November 11, 2005 Share Posted November 11, 2005 When my 1st R380 was fitted the clutch plate wasn't touched, it was just a straight forward bolt on job, the gearbox it replaced was a LT77. Quote Link to comment Share on other sites More sharing options...
LR90 Posted November 11, 2005 Share Posted November 11, 2005 When my 1st R380 was fitted the clutch plate wasn't touched, it was just a straibght forward bolt on job, the gearbox it replaced was a LT77. And can anyone tell us if an LT85 has the same spline on its input chaft? Quote Link to comment Share on other sites More sharing options...
cols110 Posted November 11, 2005 Author Share Posted November 11, 2005 Yep thats 2 down, and LT85 to go. Quote Link to comment Share on other sites More sharing options...
Bush65 Posted November 12, 2005 Share Posted November 12, 2005 LT95 has a coarse spline, compared to LT77 but you did not ask that Quote Link to comment Share on other sites More sharing options...
cols110 Posted November 12, 2005 Author Share Posted November 12, 2005 Interesting, so the question now is, is the 85, fine like the 77 & 380 or course like the 95. Quote Link to comment Share on other sites More sharing options...
